Hello,
I want to make a purchase of these components, with the aim of using the softwear for video mixing:
1 NUO3 mixer from Eclerc
3 VirtualDJ XP10
My question is on how to connect these components togeather to achieve proper operation of the softwear,( Ive been searching for diagrams or instructions but have not been able to locate any ) and if there are any other parts I need to purchace besides the laptop. I also want to mix with 3 decks hence my listing 3 of the XP10. Does the softwear support 3 source mixing...or is there a specific skin that will...or will this be a feature that can be added ASAP from a programming perspective? If so what is that process for rolling that level of mixing out in softwear upgrades, and to achieve this control and interactivity using 3 decks or more for that matter, what type of hardwear configurations as far as the number of USB inputs etc will a laptop have to have in order to do this?
Thanks in advance for your assistance.....Ive been watin for a product with this level of control for video mixing.....been researching for a while.....not much out there that works this well.....good timing, and a great alternative to DVD based video mixing!
3 VirtualDJ XP10
geposted Fri 06 Jan 06 @ 6:39 am
well first thing you'll need is to purchase Virtual DJ Pro. Once you get the serial please update your profile so all members will see you as a registered member and support will be much better.
For the 3 decks. At the moment the only way this is possible is either doing a multi-instance (some skins offer this so that you can control 4 decks at once on 1 screen) or you can have 2 laptops (or desktops) and synch them together via network.
Best Regards
DJ White Devil
Best Regards
DJ White Devil
geposted Fri 06 Jan 06 @ 7:38 pm
Is better for us if you don't repeat your posts. the answer is alredy in here:
https://virtualdj.com/forums/44696/Software_Technical_Support/Is_mixing_with_3_decks_available.html
geposted Sun 08 Jan 06 @ 10:43 am
