hi
someone knows how to cut the bass and drums from a song,just keep the vocal?
thx
thx
geposted Sun 08 Jan 06 @ 12:55 am
There isn't a software out there that can do that as of yet. But you can use acaellas which are just vocals of a song.
MS
MS
geposted Sun 08 Jan 06 @ 6:24 pm
The eqs are good enough. Kill the highs and lows and it'll work fine. You might here some of the melody of song but not much. To here more vocal rraise the Mid level to a little more of the middle which is set by default.
geposted Mon 09 Jan 06 @ 6:02 am
the only way i know is to take the original song and the instrumental version and match them together, then you need to invert the sound of the instrumental track, basicly all/most/some of the inverted signal will be cancelled out leaving you with a "homemade" accepella. Its not perfect but it can be made to work. if you dont have an instrumental version then you will have to loop a piece and make that work as a instrumental but if any sound differs from the loop you will hear it. Unless there is a plugin to invert sound .... this can't be done in VDJ. I have never tried this but i have heard some done.
geposted Mon 09 Jan 06 @ 2:08 pm
The TF Filter plugin will do the job to a satisfactory extent
adi'
adi'
geposted Wed 11 Jan 06 @ 1:41 pm
thanks a lot
geposted Thu 12 Jan 06 @ 10:43 am
Hello derekonline.
It is quite simple to kill bass, u just have to use the right skin to do it. I use the Platinium skin and that one allows me to kill bass, meddium and high. U can find this three options like a K mark near the BPM counter display.
Have fun.
Djtomas.
Moderated by Lady Cameron
Sorry djtomas no email address is allowed from a demo user
Have fun.
Djtomas.
geposted Sat 22 Apr 06 @ 1:42 pm
You can also find alot of acapellas depending on what type of music you're mixing.
geposted Sat 22 Apr 06 @ 2:22 pm
