Topic: keyboard shortcuts
How can I print the keyboard shortcuts from vdj. There are alot of them and I can see i may need quite a few. is there any way to print them? I cant highlight and copy so what else can I do?
geposted Mon 09 Jan 06 @ 1:45 am
i think you'll find that in due time you will make all your own shortcuts, some original one's you might like but you will feel more comfortable
I have no doubt of that. I know I will make my own shortcuts but I still think I should start with the shortcuts that are there already. How can I print them?
All shortcuts are in shortcuts.xml file, maybe rename this file to .txt (backup first) and print it as a text file...
But it has all parameters inside, not just a plain table with functions and shortcuts.
So it might be little confusing.
There is no other way anyway...
Anyone else have another idea ? something to transform the xml into a table/list somehow ?
I suppose you could screen dump the diagram from the program that lists each of the s/cuts onto a blank .doc or summink and print it that way?
P
You can just open it in Internet Explorer...
It will then show all shortcuts, and it doesn't look to messy at all :)
And of course, you can print from Internet Explorer if you want
How do I open it in internet explorer? I don't understand what you mean.
keep shift pressed and right click-->choose "open with" --> internet explorer..
just remember to uncheck the "use to open all such files" box..
cheers
