I am having problems with this plugin. Sometimes, the font comes in plain, not the script it is supposed to be. I have to delete, and then re-install. Is there another remedy I should try? I also have some features I would like to see, if possible. The ability to change the size & color of the font, and the ability to minimize the box. When you close it, you lose the name. This is a great plugin that I use all the time, but sometimes the color gets lost in the background effect. My main request is for a fix, the added features can come later. Thanks.
geposted Tue 10 Jan 06 @ 10:21 pm
Hello
geposted Wed 11 Jan 06 @ 6:48 am
Plugins don't work well with un-registered versions.
geposted Wed 11 Jan 06 @ 8:59 am
Bumping this up to see if I can get a little help.
geposted Tue 17 Jan 06 @ 8:55 pm
sorry only "Marius le malin" (French guy) can help you with this plugin
geposted Tue 17 Jan 06 @ 11:58 pm
So how do I get in touch with him, or just let him know about this problem. Going to the French forum, will not help, since I don't speak french.
geposted Wed 18 Jan 06 @ 8:52 am
When I activate this plugin it closes down virtual Dj 3.3
Does this happen to anyone else or just me?
Does anyone know how to fix it?
geposted Sun 19 Feb 06 @ 8:51 pm
As B2K would say, Bump, Bump, Bump.
geposted Wed 22 Feb 06 @ 8:44 am
