I'd like to publicly thank Jason (Cyder) for letting me borrow some of his time to help me with 3.3. There's so much for me to learn, but I'm getting there.
It took over 3 days for VDJ to analyze my 70 Gig "essential" music folders, and now I want to create an xml database for my external drive of over 150 gigabytes. I don't want to tie myself up for close to 7 days straight.
Jason mentioned a "quick" way to do this, but I can't seem to find it... can anyone point me in the right direction?
geposted Wed 11 Jan 06 @ 7:17 am
A quick way to build a database of analyzed songs? Not that I know of... maybe Jason has some trick up his sleave ;)
The only "quick" way I know of, is setting the BPM engine to "techno/hiphop" instead of "all music".
That analyzes ALOT quicker!
But its only good if you have a lot of "easy-beat" music songs, like house, dance, trance, techno, straight forward pop and hiphop, 80s and so on...
For more complex beats, you have to use the "all music" way.
What I do, when adding huge folders, is using the "techno/hiphop" first on all the songs.
That analyzes the folder pretty quick.
Then when I see or find someone wrong in that folder, I analyze those few, with the other engine ("all music").
Result is quicker analyze, and all correct... in the end :)
geposted Wed 11 Jan 06 @ 11:35 am
The quick why i was speaking of is to NOT analyse your songs when you do a scan just don't check the box that says get bpm too.
geposted Wed 11 Jan 06 @ 8:56 pm
Can Virtual D.J.s xml database be converted to an actual database (excel, for example), the kind I could upload to the D.J. Intelligence service, so my mobile D.J. clients could see (and select) music for their events?
geposted Mon 16 Jan 06 @ 6:34 am
absouletly
however the txt file is a bit easier, givin your file structure.
geposted Mon 16 Jan 06 @ 8:51 am
Jason:
Can you show me Wednesday? :)
geposted Mon 16 Jan 06 @ 6:09 pm
so no one else will now this procedure now?
can you tell us all how to update to dj intelligence too?
geposted Fri 10 Feb 06 @ 10:18 am
You have to make a little program for that as the one in the sound plugins "VDJ database Updater 1.3"
geposted Fri 10 Feb 06 @ 11:28 am
