Before buying any software I would like to know if it's optimal or at least works finely with my hardware.
I've been testing Virtual DJ and the headphone pre-listening sounds like a must have!
Does anyone know if Creative SB Audigy 2 Platinum is a good as a multi-channel card for headphone prelistening? Is it configurable? Is it optimal (I know everybody hates Creative with partial reason at least)? Does anyone know if its possible to use the frontpanel headphone out as prelistening?
Any user opinions? Thank You
damianplur
damianplur
geposted Wed 11 Jan 06 @ 7:23 am
Any sound card with at least 5.1 outputs (meaning 2 stereo outputs capability) is ok. It's all configurable in VDj software, you'll just have better quality and response time with better soundcards and ASIO support. Buy the soundcard that suits your needs, all will work with VDj.
Regards.
Regards.
geposted Wed 11 Jan 06 @ 10:59 am
damianplur,
That is my Soundcard (Audigy 2 ZS Platinum) and is working with prelistening and with TCVs also... so I can tell you that this Soundcard works fine!!!
You also can ask in the spanish forum if you wish... I'm from Mexico Too.
Saludos!
Saludos!
geposted Wed 11 Jan 06 @ 6:28 pm
