Is there any easy way to switch the audio settings from Timecode to regular mode? Im asking because kets say I have a play list for dinner music but then I want to go into time code mode to mix for the dance part of the gig but then later i might need to go back to non-time code mode. the only way I see is to go into the sound config. Any ideas?
geposted Thu 12 Jan 06 @ 12:59 am
A lot of skins have this function as a button in the skin (turn off / on timecode use)
You can also make a keyboard shortcut:
turntable >> timecode_active > on/off for one/both decks
(add same shortcut for both decks, to the same key, if you want to turn off both with one key)
hope that helps
hope that helps
geposted Thu 12 Jan 06 @ 1:55 am
