This is getting crazy!
Version 3.3
Let me explain my setup then the problem. I have a 500 Gig SATA drive with a Master folder that has folders inside like: Country, HipHop, Slow songs,...
I have an exact duplicate on an IDE 400 gig drive in the same machine. All songs scanned and analyzed.
Today when I booted up the club computer no songs in the "country" folder will load. Same thing on BOTH drives! ERROR! All songs in other folders load fine. What could cause this? The reason I have two drives is for protection. This computer is NOT hooked up to the net. I tried removing the "Database" .ini file but got the same errors. All files appear in windows and will play fine in Winamp.
PLEASE HELP!
Version 3.3
PLEASE HELP!
geposted Thu 12 Jan 06 @ 3:41 am
you need to delete the mp3database.txt file, lauch vdj and do a quick database scan.
geposted Thu 12 Jan 06 @ 4:43 am
Thanks Cyder, I will give that a try!
geposted Thu 12 Jan 06 @ 5:44 am
Well, I deleted the "MP3 Database" ansd restarted VDJ only to have the same problem. After uninstalling, reinstalling and trying a variety of other fixes I finally switched the settings in "extentions" area for MPG from video decoder to Windows media video decoder and all works fine. How would this corrupt on its own?
geposted Fri 13 Jan 06 @ 9:49 am
Maybe you have your MPG files in an AC3 Audio form and only LPCM is supported by the Internal Decoder. When is AC3 you have to use WMP as a decoder and have an AC3 codec (like AC3 Filter) installed in your computer.
geposted Fri 13 Jan 06 @ 11:19 am
I had been playing the files fine then all of the sudden this happened.
geposted Fri 13 Jan 06 @ 11:42 pm
