I have purchased this setup and I am almost sure it will work but I figured I would ask the pros so I have a Numark Battle pack with 2 1625 Direct Drive TTs a DF 950 2- Channel Mixer and a purchased copy of VDJ and 2 TCV and a sound card with these specs, will this work for a new inexperinced scratch wannabe DJ
Creative Series Sound Blaster Audigy 2 Value Model SB0400 Audio core Audio Chipset Audigy2 Channels 8 (7.1) Sample Rate 192KHz Digital Audio 24-bit Polyphony 1024 Voices Ports Line In Yes Line Out Yes MIC In Yes MIDI/Joystick No CD/Aux In Yes Spec Interface PCI Operating Systems Supported Microsoft® Windows® XP, Windows® 2000 SP3 or Windows ME System Requirements Genuine Intel® Pentium®III or Celeron 800MHz, or AMD® 1 GHz processor or faster Intel®, AMD® or 100% compatible motherboard chipset Microsoft® Windows® XP, Windows® 2000 SP3 or Windows ME
128 MB RAM 600 MB of free hard disk space
Available PCI 2.1 or higher compliant slot for the audio card Headphones or amplified speakers (available separately) CD-ROM/CD-RW or DVD-ROM drive required for software installation
Features
Features High Definition Audio Quality for Playback and Recording
24-bit Digital-to-Analog conversion during playback with sampling rates of 8, 11.025, 16, 22.05, 24, 32, 44.1, 48 and 96kHz in 7.1 mode and up to 192kHz in stereo mode
24-bit Analog-to-Digital conversion during recording in 8, 16 or 24-bit at sampling rates of 8, 11.025, 16, 22.05, 24, 32, 44.1, 48 and 96kHz
SPDIF (Sony/Philips Digital Interface) input at up to 24-bit/ 96kHz quality
SPDIF output up to 24-bit at 48 or 96kHz
ASIO drivers for low latency (=2ms) multi-track playback and recording at 16-bit/48kHz*
* Latency performance may vary based on system configuration
Sound Blaster® Audigy® 2 Value On-Board Connectors
Line level out (Front / Side / Rear / Center /Subwoofer)
Microphone in
Line in
Digital I/O (for stereo SPDIF output to Digital I/O Module**)
Telephone Answering Device in
Aux In
** Available as upgrade option
+Supports Windows XP SP2
Features
Microphone in
Line in
Aux In
geposted Sat 14 Jan 06 @ 11:01 pm
Hey dueshaky...:o)
You can see the recommended pc specs here: https://virtualdj.com/products/virtualdj/description.html which will give you and idea of the system you should be looking to get to run the program.
Hope this helps a bit. As for the gear aspect of things, i.e what you will be using (TT/TCV/Console/TCCD etc) have a check around the 'Hardware' forums for help there - https://virtualdj.com/forums/31/Hardware_Technical_Support.html
Cheers...keep spinnin'...:o)
P
P
geposted Sun 15 Jan 06 @ 4:23 pm
I already answer this question in the hardware forum.
https://virtualdj.com/forums/45097/Hardware_Technical_Support/Please_Help_will_this_work.html
Please post only one time your questions in the proper forum.
geposted Mon 16 Jan 06 @ 9:14 pm
