I am using vdj 3.3 with u46dj and stanton c501 cd decks, the quality reading is 100 percent and everything works fine. The problem i am having however is once in a while the program seems to loose stability and messes up on the song for a split second and then continues. This happens maybe once in a song at a random place, and can be quite annoying because i expect good performance out of my gear. I am using a 2.8 ghz pentium 4 laptop with 1.25 gig ram and my cpu usage for the program is pretty low so its not the comp.. I dont understand why i purchased this program for so much money if its so unstable... so i am assuming something is wrong with my particular settings .. or etc
geposted Tue 17 Jan 06 @ 12:13 am
*I also tried to play around with the buffer but it doesent seem to do anything at all, if i put it very high or very low..
geposted Tue 17 Jan 06 @ 12:15 am
Wait for the next update ;-)
geposted Tue 17 Jan 06 @ 12:18 am
@21 grams. Have u tried setting your reactivity to slow. Also if your timestretch is on it demands a lot from your computer. Hope it helps. I also use the U46DJ with TCV's n it works fine I don't think there's a major difference performance-wise between TCV's n TCCD's. Hope this helps.
geposted Tue 17 Jan 06 @ 12:43 am
