Hi Hi Hi !!!
http://www.zikinf.com/logiciels/warez.php?soft=187
il the link is over search the VST delay lama.
Yahoooooooooooooo !!!
U115
U115
geposted Tue 17 Jan 06 @ 10:58 pm
U115,
This VST sounds alone when activated? or sound with the song in the back too?
geposted Sun 29 Jan 06 @ 8:23 pm
the VST sound is alone!!
geposted Sun 05 Feb 06 @ 1:19 am
The end link fails :(
geposted Sun 05 Feb 06 @ 2:59 am
tip delay lama in google search!
ciao
ciao
geposted Tue 14 Feb 06 @ 12:22 am
Ok. Done!
It's the first link...
You have to give them the e-mail. Just downloaded. Goin' to try it.
geposted Tue 14 Feb 06 @ 4:25 pm
pls post your review pdnmusic. thanks.
geposted Tue 14 Feb 06 @ 9:46 pm
REPORT:
I place the VST on FX and when I play it does nothing (???).
Tried with some buttons to change values, but same = nothing.
I can see the options new window and modify values without any new sound.
I have to check it better, or maybe I'm not using it right.
geposted Wed 08 Mar 06 @ 3:20 pm
he he!! no panik
Put your mouse on the VST, in the big case and put long the song come!!!
geposted Fri 10 Mar 06 @ 5:25 am
Ok. Thanx... I managed to make it work.
REPORT:
- You need to have the playing the song of the DECK where you have this PLUGIN.
- Then when click on the PLUGIN button to activate it, the song doesn't sounds. So it's not a OVER SONG FX, it's more like a new instrument (hehehe).
- You have to click on the "1" button of the PLUGIN so the Delay Lama appears.
- Then moving the mouse on the box under the "delay lama" picture the voice starts and sings.
It's funny, I have to check it when mixing, hehehe...
REPORT:
geposted Thu 16 Mar 06 @ 2:14 pm
lol i m happy that you find this effect crazy!
geposted Thu 30 Mar 06 @ 3:13 am
Still not used on a live mix... Always remember to use it when ended. :(
geposted Thu 30 Mar 06 @ 4:00 pm
Ohhhh!! This effect is very veryy goooood man!!!
geposted Fri 21 Jul 06 @ 12:42 am
Great Effect , Thanks for the Link
geposted Sat 22 Jul 06 @ 10:17 pm
But I can't help because I'm not right
geposted Thu 09 Nov 06 @ 11:07 pm
It's always, it's always this way
lol
geposted Mon 13 Nov 06 @ 6:00 pm
A french producteur has make a track with this effect ;-)
http://joris.delacroix.free.fr/extraits/freetibet-extrait.mp3
>>Joris D.
Enjoy !
>>Joris D.
Enjoy !
geposted Sun 03 Dec 06 @ 9:26 pm
geposted Sun 03 Dec 06 @ 9:33 pm
>>Joris D.
Enjoy !
>>Joris D.
Enjoy !
hehehehe...
geposted Wed 20 Dec 06 @ 3:10 pm
