How do you use the fader start plug-in?
geposted Wed 18 Jan 06 @ 8:48 pm
Hehe...no idea!!! Just tried it myself.
DJcel????
P
DJcel????
P
geposted Wed 18 Jan 06 @ 8:59 pm
When the plugin is activated, when you move the crossfader on the skin (or with a midi controller) the deck starts from the position defined by the last slider on the right
You have an option for FaderStart to use the function sync() instead of only play()
The first and second slider are linked to the volume (i couldn't test as for the crossfader)
The third and forth slider are options for the FaderStop
geposted Thu 19 Jan 06 @ 1:06 am
where is the fader start plug in - i cant see it on v3 vdj -
geposted Fri 20 Jan 06 @ 1:05 am
davefromlondon
try this: https://virtualdj.com/addons/download.html?addon_id=813
cheers...and keep spinnin'...:o)
P
P
geposted Fri 20 Jan 06 @ 1:47 am
I downloaded plug in, dble clicked on .exe file, it said it installed - but I see nothing on VDJ to use it or initiate it - I just want to start playing the song by 'slammin' with the fader on a predetermined start point - surprised this common fade method not native to software
geposted Wed 01 Feb 06 @ 1:43 am
