When in AutoDJ mode(the star is on), If I click the automix and in the time of the fade the song reches the point that VirtualDJ wants to mix(ie the end song point) then the fade begins from the start again.
VirtualDJ should recognize if it is currently in a fade proccess(automix) and do nothing if it is.
10x
Ziv
10x
Ziv
geposted Thu 19 Jan 06 @ 9:06 am
are you saying it keeps repeating the crossfade? i noticed that if i loop and try automix (which i never use) the fade begins and then reaches like half way and then starts again, are your songs looped?
geposted Thu 19 Jan 06 @ 2:47 pm
they are3 not looped, I am only using it to play songs, but if I click the auytmix when the song getting close to the end of the song(auto cue points) in the middle of the fade it starts all over again and does the fade.
geposted Thu 19 Jan 06 @ 4:17 pm
