help installing my dm2 into virtual dj
geposted Fri 20 Jan 06 @ 12:44 am
unfortunatelly I don't think the mixman DM2 is compatible with Virtual DJ.
If you are looking for a controller to use VDJ with you can get a DAC1, DAC2, DAC3, XP10s, Hercules DJ Console, Hercules DJ Console MK2, 2 turntables and an external mixer using TCVs, 2 CD players using an external mixer using 2 TCCDs, And you can also use a midi controller and I'm sure there are many more controllers available although these are the main ones that I know which are compatible with VDJ.
If you cannot afford such controllers you can always just purchase VDJ Pro and still be able to mix without the use of a controller and maybe later on you can start off with a mixer and continue investing into a personal DJ setup ;)
Best Regards
DJ White Devil
Best Regards
DJ White Devil
geposted Fri 20 Jan 06 @ 6:21 am
i might be given one in the next few days , so if i am il try and make a mapper so that it can talk to VDJ
geposted Sun 28 May 06 @ 12:15 pm
