Yeah, i just bought the dj console mk2. I installed it and it worked perfectly, but then I updated it using the virtual dj djc v3.3 update and it stopped working. All the buttons stopped functioning and only the play/pause button and the cue lit up. I belive it was the update that caused the problem. Am I right and can I reverse it and remove th update or am i wrong. If so help me out please!
geposted Fri 20 Jan 06 @ 4:10 am
https://virtualdj.com/forums/44271/Hardware_Technical_Support/HERCULES_DRIVER_UPDATES_FOR_VIRTUAL_DJ_3_2.html
The firmware and driver is update ready for version 3.2?
You can download here ftp://ftp.hercules.com/pub/webupdate/DJMk2/2_CMK2_2005.exe The driver work for version 3.2 and 3.3.
geposted Fri 20 Jan 06 @ 1:47 pm
What do I do
geposted Sat 21 Jan 06 @ 12:06 am
You can Install the new update ftp://ftp.hercules.com/pub/webupdate/DJMk2/2006_CMK2_1.exe
geposted Sat 21 Jan 06 @ 1:54 pm
it didn't change anything
geposted Sat 21 Jan 06 @ 8:22 pm
hi guys...
I'm always looking at this forum, hoping that someone finds out how to solve that problem, cause, guess what, i have the exact same problem.
I contacted them, for the second time (today). Hoping that this answer will be the one helping me :)
cause the new update they've put in my inbox, just didn't do anything...and won't, i think. cause it's not about drivers or software. i think the updater updated the firmware of the console...and it won't recognize my dj console ever again ;(
mavsrule08, did u find out how to solve the problem? or r u still on it?
geposted Tue 14 Mar 06 @ 10:26 am
did you guys try to uninstall VirtualDJ, go to Program Files folder, delete the folder VirtualDJ, and then reinstall the software?
If there is a problem get back to the original VDJ Version given on a CD with your djc mk2 box.
geposted Tue 14 Mar 06 @ 2:37 pm
Maybe DJ Console MK2 updater didn't work on your PC.
Can you run the Hercules updater program on another PC (it doesn't require VirtualDJ to be installed) to reflash DJ Console MK2 ?
geposted Tue 14 Mar 06 @ 3:43 pm
i did all this but there is no solution i think that the best think to do is to remove the firmware but i just havent found the way to do it
geposted Tue 14 Mar 06 @ 9:38 pm
Did you try to call Hercules Tech support ? I got the same issue and they have been able to fix the issue... You have to use the updater in a "Manual mode". Launch the HDJ2Updater.exe program with the "-manual" command line. It will give ou some information of the current firmware version you have.
geposted Wed 15 Mar 06 @ 5:35 pm
can you explain furthermore
geposted Thu 16 Mar 06 @ 2:40 am
You can post your message on Hercules tech support
http://ts.hercules.com/eng/index.php?pg=login_page
The tech support will ask you a few operations to check with you which firmware problem in order to flash the firmware in the appropriate way.
It doesn't make sense to disassemble a component of the console while the firmware can be reflashed by the USB port, but you must contact the tech support first so that they test with you which version of firmware you need to make sure you flash the right firmware.
geposted Thu 16 Mar 06 @ 6:52 pm
Same problem here, but with MK1. Where can I get the HDJupdater file you mention?
geposted Wed 12 Apr 06 @ 5:21 am
mtlvince I have no answer from Hercules tech support. Could you upload or email the manual updater you mention somewhere? I will be immensely thankful.
geposted Wed 12 Apr 06 @ 3:32 pm
