I would be cool if there was a bpm tap button to input bpm manualy like on my Denon 5000s
geposted Fri 20 Jan 06 @ 5:24 pm
It already exists in the "edit bpm" window ;-)
geposted Fri 20 Jan 06 @ 5:45 pm
Thanks i didn't konw.
geposted Sat 21 Jan 06 @ 3:13 pm
i would love a function that goes rite there so i can map it to say "spacebar" and go ahead and tap on spacebar to let VDJ know the approx BPM.
Then (naturaly) the lock-on BPM function would use this and find the right BPM for a change (not double, half or 4/3 etc etc etc) i think that if the VDJ BPM engine could be told where it was ether with a tap or by range of your analysing say a hiphop CD that you know is above 90 but below 110.
please give it a thaught because VDJ relies massively on accurate BPMs to work properly. and i ahve nearly totaly lost the ability to match by hand anymore! stupid VDJ grrrrrrr............................
geposted Wed 25 Jan 06 @ 3:36 am
come on this is a good idea, vdj would be so much faster to use if you didnt have to spend ages finetuning all the bpms.
geposted Fri 27 Jan 06 @ 2:20 am
