how do i connect my laptop to the cd decks/mixer and sync it up with the time code cd?
geposted Sat 21 Jan 06 @ 8:52 pm
You're going to need a sound card with the correct inputs/asio capabilities. A common one used is the Maya 44 USB external soundcard. You run the output from your cd decks into the inputs and put vdj in timcode mode. Then you run the outputs into your mixer. And that should do it.
geposted Sun 22 Jan 06 @ 12:25 am
