Hi Im A Dj and I also do computer repair/hardware and build pcs. my mp3 collection is over 16 thousand and I need to sort them. I manually organized most of my albums. How do I cross referance them the easiest way for sertao by rane or virtual dj. I might start doing gigs again and need a way to sort all this and in an easy way. If anyone can help this would be great sorting 16 thousand plus mp3s is nuts. Maybe sumthin or sum kinda program that sorts them for me we be great.
Lemme know
Logic
Lemme know
Logic
geposted Mon 23 Jan 06 @ 1:42 am
login54,
With Virtual you only have to analize your songs and before that you only type for the name or the artist or a text which matches your comments or the name of the album... and you retrive your song in a sec.
You could sort also by Artist, by Song name, By BPMs, and Comments also if you whish...
geposted Tue 24 Jan 06 @ 5:27 pm
I have over 70,000 mp3's so i know exactly what you mean.
There is no easy way, here are a few examples.
group them in folders like;
60's
70's
80's
90's
2000
or perhaps genres like;
house
disco
rnb
rock
etc
I know it is a tedious task but the easiest way is to rely on you music knowledge and simply do a local database search for artist, songtitle, etc. like acw dj suggested.
It only takes seconds
Cheers.
60's
70's
80's
90's
2000
house
disco
rnb
rock
etc
Cheers.
geposted Wed 25 Jan 06 @ 7:36 am
Another thing is that in the name or directory of the file is a name, it is search by VDJ as well. In the last example:
If you are in local database (in search) and you type House you find all your files listed in VDJ that are in the directory house in your harddrive. Same if you search for 90's ... I have some of my files in genre directories, when I put "latin" then all these are displayed in VDJ.
geposted Wed 25 Jan 06 @ 12:31 pm
