Some of us complained about the bad sound of streching. So there's a technique to have a better quality with this feature.
Usually when a mix starts, the pitch is 0 and when the next song is loaded, its pitch will change to feat the bpm. The problem is when the pitch changes a lot, the sound is distorted WHEN THE SONG BEGINS.
With the method, the sound will be distorted as well, but only at the END of songs, letting you to start the songs in the best sound quality (pitch=0).
So start the first song, and load another one in the other deck. The freshly loaded song's pitch is 0, as you just loaded it. Then slowly change the pitch of the first song (with the arrows 'fine pitch') to match the bpm of the unplayed song, which has always its pitch set to 0. When the BPM is matched, start your second deck, the starting song plays with the highest possible quality!!, as the streching has been applied to the ENDING song.
Repeat the technique to each song in the mix, and your mix will sound a little better.
You know, if you change the playing song's pitch instead of the next song's pitch, it will be better.
FRUiT94
FRUiT94
geposted Thu 06 May 04 @ 2:26 pm
          You can see more detailed informations in the page bellow :
http://www.virtualdj.com/forum/display.html?topic=4532
FRUiT94
FRUiT94
geposted Fri 07 May 04 @ 3:21 pm
