I have heard alot of good things about the Numark USB Mixers... but one thing i am unsure of is weither the onscreen eq volume and crossfaders will follow the one on the mixer like with HDJ Console MK2 or if the will not respond when using the mixer Im thinking that they should be easy to map aslong as the mixer has somekind of midi interface or midi drivers please let me know im very intrested in getting one
Also these mixers come with asio drivers right i wont need anyonther soundcards if i want to use TCV right ?? ??
Thanks again
Thanks again
geposted Tue 24 Jan 06 @ 9:14 pm
Another Question if anyone gets around to reading this does anyone else make usb mixer similar to the ones from Numark ??
geposted Tue 24 Jan 06 @ 10:30 pm
KK-DJ,
The problem with Numark USB is only that as they are cheap, they have more hum& noise that other Mixers. Anyway the CM-200USB seems to be a good option. I better use the DJC2 now, but Numark USB mixers are a good option to use with TTs or CD-Players and a PC.
geposted Wed 25 Jan 06 @ 11:10 am
