Hai to all
Ok so i recetly downloaded an effect named longbrake, i started it, but it didnt load on the virtual dj fx menu...so i decided to exit, and reboot the program. When i did, i got an error message saying "installation error" and now it wont let me start up virtual dj..any thouhts on what is occuring?
geposted Thu 26 Jan 06 @ 4:55 am
Hi,
never heard about this problem. What I would do in your case is unistallig VDJ, deleting virtualdj folder, reinstall the program and don't try again with this plugin...
geposted Thu 26 Jan 06 @ 11:03 am
Did you install the .exe of the plug in? Or did you just put the exe under the plugins folder?
Anyway you should make the backup of the Virtual Dj folder (the mp3 database .txt & .xml, skins & effect plugins), and than reinstall the software (also clean the registry entries if you are experienced), install the long brake plugin and start VDj. It should work.
geposted Thu 26 Jan 06 @ 11:09 am
thanks guys...i just sent them a message seeing if they could unlock my account for a new download they did i reinstalled it and now it works :P
geposted Fri 27 Jan 06 @ 2:53 am
Strange to get "installation error" with the plugin. The plugin can't do that if it's well installed
Do you have an idea of the bad thing you did? I think it's interesting to know
geposted Fri 27 Jan 06 @ 12:58 pm
