Hi djcel;
I just discovered and tested your "long brake" plugin. I really like it. Thanks.
One suggestion:
_____________
5 buttons with a slider for each one to change the length value and autosave settings.
What do you think ?
One suggestion:
_____________
What do you think ?
geposted Thu 26 Jan 06 @ 3:48 pm
yes why not
geposted Thu 26 Jan 06 @ 4:48 pm
Usefull effect :) good job.
geposted Sat 28 Jan 06 @ 12:44 am
Hi , in my Laptop dont work , the sound is going mute when it activated..
geposted Sat 28 Jan 06 @ 5:48 pm
anyways to alter the pitch on the brake as the sound is winding down?? EX. +4, +1, -4, -8 having each play for about 1 sec and the last (-8) would be 2-3 seconds. That would be like a tear drop scratch effect.
geposted Tue 31 Jan 06 @ 3:34 pm
Hi, i need a source code of this plugin to make little changes.
If is possible can u send me to my email? xxxxx@gmail.com
Thanks,
From Argentina
Edit by Cioce
No license user can't write personal emai in the forum
Thanks,
From Argentina
Edit by Cioce
geposted Thu 06 Nov 08 @ 1:58 pm
Sorry, plugin source code is not available to unlicensed users.
Plugin source code is available to licensed users at the discretion of the original author of the plugin.
geposted Thu 06 Nov 08 @ 9:16 pm
