Hi, does the HerculesDJ Console Mk2 allow recording of musice and voice using a microphone? I have tried and the music is recorded fine but the voice does not recorded or is too low to hear.
geposted Fri 27 Jan 06 @ 5:28 am
On DJ Console MK2, you can select the audio input you record on input 1/2 in DJ Console MK2 control panel (on the control panel, in bottom left button), so you select the audio input you want, either line in (input 1/2) or microphone In, but you don't mix both analog inputs in the same input 1/2.
If you are in VirtualDJ, and you want to record your music mix together with your microphone input, the simplest solution is to
1) loop an audio output: you have 2 output 1/2, 1 in dual RCA, 1 in jack 1/8", so you can listen 1 and loop the other output in a line in: either your computer sound card line input or your DJ Console MK2 line input
2) select the line in source your want to use as recording source (Start > Settings > Control Panel > Sounds and Audio peripherals > Audio) and select your the line in you want to use as Sound Recording default device
3) Run Windows Media and record while mixing with VirtualDJ.
geposted Mon 30 Jan 06 @ 4:06 pm
