I wasn't at a gig or anything, just messing around while doing some other stuff. Everything was working fine until I plugged in my USB soundcard so I could preview other songs with my headphones. Every once in a while, the music would skip a fraction of a beat. I restarted VDJ, but it didn't help anything. I just ignored it and figured it had to do with the fact I was doing other things at the same time (word processing, etc.). Then when I was doing a mix, I was nudging one of the decks, and the program just closed. No recovery message or anything, it just closed itself. I will try to make it happen again so I can see if I can figure out more details.
geposted Sun 29 Jan 06 @ 1:10 am
Check your cpu's temperature, just in case.
I had some weird crashes sometime only to find that the cooling was bad and cpu was very hot.
This was in a computer permanent installed in a club, where dust was the reason.
geposted Sun 29 Jan 06 @ 3:21 am
