Forum: Old versions
Topic: Pitch Bend
In the VDJ configuration can I modify the amount of pitch bend that is applied when using the console's pitch bend buttons?
Thanks
geposted Sun 09 May 04 @ 9:51 pm
No, I don't think you can.
But the best way to pitch bend with the DJ Console is the jogwheels.
Once you have some skill with it, it is far better than buttons!
kaléo.
