hello, i just bought a hercules dj control mp3 console for about 100 euros, and i installed all the new updates on the site, my system specs are AMD Athlon 3800+ 64Bit X2 Dual-Core cpu, with 2gb ram and a sSoundBlaster live 24-bit soundcard, And this is the problem i have: When mixing with the console we get, after aproximatly 2hours, a fatal error. We can only choose between 'Recover or 'End'.
Both options close the program and the music stops, which is, as you see, unexpected and unacceptable. Can you help me and come up with a sollution please?
Greets.
Greets.
geposted Tue 31 Jan 06 @ 11:18 pm
is there a dutch team which i can write or call to ?
geposted Wed 01 Feb 06 @ 12:09 am
well that sucks. sometimes when you have a problem like that you can go back to a different version and see if it still happens. or you can format the computer, or you can change things about and see if it stops the problem. i hate niggling problems that have no obvious cure. computers are full of them. get a linux version VDJ.
geposted Wed 01 Feb 06 @ 12:39 am
That really sucks, no one have a answer?
geposted Wed 01 Feb 06 @ 1:20 pm
What is the amount of your virtual Memory? I think is a Windows problem, How much HD space is left in C or in your current music drives? Did you have swap allocation in you music HD drives is the same as C or Windows system?
geposted Wed 01 Feb 06 @ 9:23 pm
"We can only choose between 'Recover or 'End'."
Really on the last update (3.3) you got this window?
geposted Wed 01 Feb 06 @ 11:26 pm
Funny i get the same fatal error on mine when i play some songs but when i scan the file to check its currupted it come back ok.
Another thing, I cant seem to get updates i bought the new mixstation 3 last year not long after it was released but when i go to updates, it either says your serial is registered to someone else or no updates and i can see that they are updates available but now for me :-( why.
Help
Daktadre aka Badman
Help
Daktadre aka Badman
geposted Tue 07 Feb 06 @ 4:39 pm
you won't get any uptdates ith DJ MIX STATION 3, because it is a home edition and it is stable.
if you want to get all the updates you will need to upgrade to VirtualDJ's Pro version.
geposted Wed 08 Feb 06 @ 12:08 am
