Forum: VirtualDJ Skins
Topic: Advanced default by cioce v1.0 (1024x768) - Page: 1
ciocePRO InfinityMember since 2004
Hello guys
This is my first skin based on djjb Advanced default, what do you think? http://www.virtualdj.com/blog/cioce/
- Clock and counter are divided in two different top positions near the Master tempo on-off switch.
- Blue tooltip indicator on every generic button and yellow on the pitch.
- Double gain and volume sliders, you can choose both or only volume or only gain for each player.
- Double time indicator, from start & to end or to start & from end of the beats near the turntable and switched by click on.
- Another time indicator for spent & left time fix under play and stop buttons.
- Nudge / scratch buttons on the turntable for mouse and/or console.
- Time code vinils on/off buttons on the turntable.
- 12 sample-buttons, included load-buttons for each sample in left side (blue color).
- Red Fx, yellow Cue and green loop buttons colors, like DJ console leds.
- 3 central panels (audio, video, panel setup) selected via top-left button.
Audio with standard crossfader equalizator
Video with:
- Video window open/close button - auto - only 1 - 1+2 - only 2
- Fx on/off button with regolation bar
- PI = FX Plug-in button selection
- 4 different transitions button
Panel setup:
- Top display switch in two mode, rhythm or active song name (click on the song name to see www.virtualdj.com but is possible to customize the words inside the xml file).
- Normal or console Fx button order.
- Double level-visuals displayed, you can choose "position of slider" or "output level" inverted.
- Virtual DJ or VDJ discs with | (vertical line) good to find the position of the disc in scratch mode.
- 5 different crossfader curve selections.
This skin will be available in the next days only for Professional Edition Users.
Enjoy Mix
Cioce
geposted Thu 02 Feb 06 @ 11:32 pm
JeremKPRO InfinityStaffMember since 2004
i never really liked the look of that skin (personal view) but i know quite alot of people use it, and it is a very good idea to make a professional version of it.
you should maybe change the "search" button in the center of the skin (between "music" and "fx") into another button like video, because it doesn't have anymore use since VDJ 2.0
anyway, good work!!
geposted Fri 03 Feb 06 @ 12:14 am
listen2PRO InfinityMember since 2005
Yes good work is that a split fader for video??? nice! ..........just way too many default looking skins( for me personally)
geposted Fri 03 Feb 06 @ 4:08 pm
geposted Sat 04 Feb 06 @ 3:39 pm
good idea for the master tempo in place of search button.
geposted Sat 04 Feb 06 @ 5:31 pm
djcelPRO InfinityModeratorMember since 2004
Professional Edition Users level taken in account
(the next time write it ;-) )
geposted Mon 06 Feb 06 @ 7:22 am
geposted Thu 09 Feb 06 @ 9:12 pm
Version 1.1 updated with lej78480 idea applied.
The volume and gain slide are redraw, Video window open/close button - auto - only A - A+B - only B, 3 central panels (audio, video, panel setup) selected via central button near the Master tempo on-off switch and top button and timer moved.
Direct link download >> http://www.virtualdj.com/addons/download.html?addon_id=1612
geposted Thu 23 Feb 06 @ 11:41 am
geposted Fri 03 Mar 06 @ 9:15 am
geposted Mon 06 Mar 06 @ 12:53 pm
geposted Wed 08 Mar 06 @ 8:43 am
geposted Wed 22 Mar 06 @ 10:30 am
geposted Sat 25 Mar 06 @ 12:42 pm
geposted Sun 02 Apr 06 @ 4:14 pm
HaywardPRO InfinityMember since 2005
I like the skin, however the colors need work, the gray does not work for me.
I still like all the functions, keep up the good work.
geposted Tue 04 Apr 06 @ 12:50 am
geposted Tue 04 Apr 06 @ 11:45 pm
My skin v2.0 was upload 2 week ago? Why is not update?
geposted Sat 15 Apr 06 @ 6:10 pm
Thanks for the nice skin.
One thing I would love to see in this skin and I think other would agree would be tool tips on all of the other buttons and switches. Besides generic.
Nice
geposted Sun 16 Apr 06 @ 8:43 am
The toll-tips are write inside the language file ( LANGUAGE.XML ) maked by Virtual DJ team, try to open the file with text editor and insert the new commands who you want.
PS please VDJ team insert all the commands in the tool-tips file, I don't want to make this work by my self.
geposted Sun 16 Apr 06 @ 10:57 am
geposted Wed 19 Apr 06 @ 8:30 pm
69%
