I can't use the accelerator as it says I need direct X 9. My DJ computer is never connected to the internet. I'm not able to copy to my desktop and then transfer direct x to my dj computer. Any suggestions?
Also, I have not upgraded from 3.1 to 3.3, 3.1 works fine, will I need direct x 9 for 3.3?
geposted Sat 04 Feb 06 @ 5:12 am
As far as I know, DX9 support was started in version 2.1. If you want to check your directX version, go to Start Menu -> Run and enter "dxdiag".
If version 3.1 works then you should have no problem with 3.3, however, you can download directX from http://www.microsoft.com/directx/ and burn it to a CD or put it on a USB key or something and transfer it over to the computer. I know you say you are "not able to copy to my desktop and then transfer direct x to my dj computer", but I don't see any reason that you wouldn't be able to unless your DJ computer's CD drive and all it's USB ports are shot.
geposted Sat 04 Feb 06 @ 9:01 am
What video card are in your coumputer? Because if it is not a DirectX 9 compatible that's a problem too.
geposted Sat 04 Feb 06 @ 6:31 pm
I think you have to be connected to install dx9.
As I remember you click through a authorization (which you can bypass) and then download an install.
Then you run the install and it then connects to MS for the install and won't until it does see internet.
At least that is how I remember it, things may have changed since.
Correct me if i'm wrong
geposted Sat 04 Feb 06 @ 9:04 pm
Here's a download link for the DirectX 9.0c package:
http://download.microsoft.com/download/1/1/d/11d253f5-be20-41eb-8985-29a44c601264/directx_dec2005_redist.exe
geposted Sun 05 Feb 06 @ 1:37 am
