I have downloaded several effects for vdj. only one has gone into vdj for me to use. how do I get the others into vdj fx?
I have all of them in the correct folder (vdj effects)
all but the one that works showed up in the folder with an icon of a red present giftbox.
Can someone PLEASE help me with this, i want to use these effects today on the radio.
Thanx in advance
Thanx in advance
geposted Sat 04 Feb 06 @ 5:45 pm
The gifbox is a installer (.exe) so you have to click on it to install the plugins. It will send the .dll file directly in the good folder. It's the new system.
geposted Sun 05 Feb 06 @ 1:08 am
And sometimes you have to restar VirtualDJ to see the new effects.
geposted Sun 05 Feb 06 @ 3:17 am
Just install them when VDJ is closed !!!!
geposted Sun 05 Feb 06 @ 12:24 pm
