I have a question regarding the soundcard of that mixer from NUMARK, would if be necesary to have a MAYA44 soundcard or something similar to control VDJ or pluging the turntables to the DXM01 would give control via TCV's or TCCD's?
Thanks in advance.
Alejandro.
Thanks in advance.
Alejandro.
geposted Sat 04 Feb 06 @ 5:49 pm
the dxm01 USB only has outputs, which means it acts like a soundcard that has 2 stereo outputs.
if you want to use the TCVs with that mixer you will need an ASIO soundcard with 2 stereo inputs, like the maya44usb.
geposted Sat 04 Feb 06 @ 5:55 pm
alx2k,
You need to route the Phono inputs as an input in the soundcard and also use the outputs of the soundcard to switch it to the channel one IN the mixer and Channel 2 also... That's no posible in the DMX01 USB.
Numark Don't made this Mixer (unfortunatelly) to use their Phono or Line INs and inputs to the USB soundcard and let the outputs to be mixed by the Channel 1 and 2 of the DMX01 Mixer.
geposted Sat 04 Feb 06 @ 6:23 pm
Thanks for the help, it was just a question thought. As you see, I just registered, one thing left to do this month... buy BCD2000 when it comes out.
:P
Alejandro
:P
Alejandro
geposted Sat 04 Feb 06 @ 7:45 pm
alx2k,
Alejandro WELCOME as a full VDJ member. You can now have access to some other forums and also to more information. Take a look over the forums, read and ENJOY VDJ!
Congratulations!
Congratulations!
geposted Sun 05 Feb 06 @ 12:01 pm
good luck with your BCD2000 too,
that's a joke.., we're waiting for it about a year now..
geposted Sun 05 Feb 06 @ 1:44 pm
I know they are delaying the release of that controller.... for years.... but seems like it's going to be finally released in mid Feb beginning of Mar. If not... I'll have to go for Mk2 or make an investment and buy TT's, maya44 and mixer
BTW, anybody around here has Mk2 and TT's? how does it work with TCV's? is the latency much higher that with maya?
Thank you,
Alejandro.
Thank you,
Alejandro.
geposted Sun 05 Feb 06 @ 4:44 pm
I got 14ms with my Mk2 (using TCV) although it could probably go down a bit, I was running lots of unnecessary system processes and high ram using applications like Azureus.
The advantage of the Mk2 over the Maya is you can create cuepoints, loopss and effcets from the console. Also there is a hardware vinyl bypass so you can play nonTCV at the press of a button without any noticable quality degredation (I didn't test this for too long however).
geposted Sun 05 Feb 06 @ 6:06 pm
Hi there....up late playing with this thing....love the pro version...I want to upgrade to an externnal mixer.......I do not have turntables or cd players...yet, but want to start with an external mixer...any suggestions for brands, ease of use, and sound quality to use with my laptop?? THANKS!
geposted Sun 12 Feb 06 @ 6:00 am
