While in auto play I find the fader locks to the player in use in the final moments of the track.
This is a problem when the outro is too long and I want to cut it short.
I find that even if I hit "mix" to shorten the outro that it will mix and then when the non-active player does end that it restarts the live deck.
The bigger problem is that the fader locks and springs back when I attempt to drag it to the other deck even with the auto play turned off.
This makes for an embarrasing moment struggling with it and the resulting dead air.
Any thoughts?
Any thoughts?
geposted Tue 11 May 04 @ 1:12 pm
