Hi,
i`ve a very easy question. Can I use the VDJ witn a Maya 44 PCI ??. My Problem is that i find the Maya 44 PCI in a shop in my country and I culdn`t find the Maya 44 Usb in my country but yes by internet
geposted Mon 06 Feb 06 @ 4:14 am
Should work just fine, the maya 44 usb are well-suited for mobile users, but as the name says 44 it holds 4x ANALOG IN + 4x ANALOG OUT, which is required for Timecoded vinyls/cds especially. (Ofcourse it works perfectly fine if you dont plan to use TC vinyls/cds).
geposted Mon 06 Feb 06 @ 12:41 pm
With the maya44pci, you will have an even better latency, something like 1-2 ms less than with USB.
geposted Mon 06 Feb 06 @ 10:31 pm
Some users have problems with some Maya 44 PCI. DOn't know why exactly, but I recomend you that before buy you try it. If you couldn't do so, then is better to use a M-Audio Delta 44 PCI or a Delta 66 becuase work better.
Good Luck!
PS. Don't forget to buy VDJ Pro to get all this working as it should, ilegal copies of VDJ don't work well.
Good Luck!
geposted Wed 08 Feb 06 @ 12:08 am
