Forum: VirtualDJ Skins
Topic: Question for Skinners
hi
I'm a Hercules DJ Console user - I have the Console Version of VirtualDJ
I was wondering if it is possible to reverse the crossfader thru the skin to give the effect of a 'hamster switch' on a scratch DJ mixer
any thoughs on this would be appreciated
thanks
[echorec]
geposted Tue 11 May 04 @ 4:49 pm
1 - edit the xml file (with notepad) contained in the .zip of your preferred skin
2 - do a search with the word "crossfader" you should see a line called 'slider action=crossfader'
3 - in this line add or modify the parameter 'direction="" '
put down instead of up , or put left instead or right and so on. if the parameter doesn't exist, write it by yourself just be carefull of the synthax you have to respect.
The skin is ready. Don't forget to update the new .xml file in the skin's archive.
FRUiT94
thanks for the speedy reply. I'll try it !
[echorec]
