Hi VDJ TEAM
One i think more simple request is the option of different broadcasting "profiles".... for instance i play at several webradios and need to enter their broadcast server infos/logins everytime i play on a different station... this is a sad process to go through each time.
So to be able to load different profiles into the rec/broadcast would be nice to use broadcast profiles or something like that if its possible. :-)
DJ TaZ
DJ TaZ
geposted Tue 07 Feb 06 @ 3:11 pm
you can use the registry for that. Save different .reg file for each profile
geposted Tue 07 Feb 06 @ 6:09 pm
good thinking my son
geposted Wed 08 Feb 06 @ 2:23 am
Sure you can do that if people have the knowledge about this ! ;-) Not everybody does.... plus this method, as i see it, (as an IT Specialist within IBM on my dayjob.) Should NOT be the way to do it, this is what you could call a workaround or if you like, a quick fix. But this is not a dueable solution in the long run.
What i'm aim'ing at here is that every user of VDJ without the big knowledge of modify'ing the registration database or other techs skills should be able to use this broadcast profile solution, if it was integrated into VDJ.
I hope you see my point and for the record i'm already using the reg db to du this, but again i don't think it's the proper way of doing it ! :-D
DJ TaZ
DJ TaZ
geposted Wed 08 Feb 06 @ 12:37 pm
i agree with you Soeren, everybody should be possible to do this.
geposted Wed 08 Feb 06 @ 11:16 pm
I wonder if anything of this could be implemented and will be in next version ?? :-)
DJ TaZ
DJ TaZ
geposted Wed 31 May 06 @ 2:12 pm
