Hi All
Is there a way to make the Pioneer skin default be scratch/nudge ?
geposted Wed 12 May 04 @ 12:49 am
Hem, you want the scratch to come first by default?
geposted Wed 12 May 04 @ 12:34 pm
Yes can this be done?
geposted Wed 12 May 04 @ 1:35 pm
Yes of course.
First unzip the skin and open the xml file with notepad. Make sure you see the status bar on the bottom of the window.
Go to the line 675
There you see pannel visible=yes. Put no instead of yes.
Go to the line 682
Put yes instead of no in the same parameter.
Ok for channel one. For channel two repeat the same operation on lines 1891 and 1898. Don't forget to save the changes and to repack the files in the zip file.
Done.
FRUiT94
Go to the line 675
Go to the line 682
Done.
FRUiT94
geposted Wed 12 May 04 @ 2:45 pm
You the man!!!!!
Thank You
Thank You
geposted Wed 12 May 04 @ 3:12 pm
Did you have a look?
Did it work? Please tell me.
geposted Thu 13 May 04 @ 9:45 am
Yes it did all I had to do was to find out what font size you were using in notepad . My font size was 10 so my line 265 was not the same but when I made it 26 and unchecked word wrap it worked. For some reason a different font size will give you a different line number. I did the same thing for the tascam skin it worked to.
Thank You again
Thank You again
geposted Thu 13 May 04 @ 10:39 am
Ok that's cool!
geposted Thu 13 May 04 @ 2:50 pm
