Is it possible to set up a keyboard shortcut that will work like the reloop feature on pioneer cdj 1000 players. I have shortcuts for loop in loop out on the fly, I would like to reloop on the fly as well. I can't figure out the combination for this. Could anyone help. Thanks.
geposted Wed 08 Feb 06 @ 7:29 pm
If you mean a function similar to Numark CD players where pressing Reloop jumps back to the start of the loop (Creating a stutter effect), this is not currently possible using VDJ shortcuts. Hopefully, the dev team will add a 'reloop' action at some point (This shouldn't be too difficult to do.)
I'm currently experementing with a reloop option (loop mode 2) in my DAC-3 mapper v2.0 (Not available yet), which is working quite well. A proper 'reloop' action in VDJ would be much better though. In my mapper 2.0, you can use reloop to stutter, as well as re-trigger the loop again after exiting the loop.
geposted Wed 08 Feb 06 @ 7:46 pm
My thoughts on reloop would be to go back to the 1st loop point and play loop from there. Maybe similar to the go to cue buttons. I couldn't come up with a combination of commands that would make this happen. You are probably right that it can't be done yet in VDJ. I will post this want in the new features forum and maybe they will add it on the next upgrade. Thanks.
geposted Wed 08 Feb 06 @ 7:52 pm
you can create a macro with a keyboard shortcut that will do this:
go to cue 1
loop 4
and then pressing that shortcut will bring the song to cue 1 and put a loop 4 in it.
go to cue 1
loop 4
geposted Wed 08 Feb 06 @ 11:54 pm
