Hey guys/gals, just got vdj pro and was just wondering if anyone can help me with connection of it to a numark dxm01 usb mixer? thanks!
geposted Thu 09 Feb 06 @ 10:37 am
What kind of connections are you looking at???
I'll leave TCV/TCCD etc up to someone who actually uses it, but i go from 5.1 soundcard to mixer. To do this, plug a cable with 1 1/4 inch jack on one end from your audio output from your soundcard to two mono plugs into one channel of your mixer and a cable of the same kind from the headphone output on your soundcard to your other mixer channel. Select the correct soundcard setup from your config menu and you should be able to listen through your speakers and cue through your phones.
I assume you just plug your mixer into your usb connection and that's you ready to go?
Sorry, i don't use a usb mixer...this is just my guess.
Cheers...and keep spinnin'...:o)
P
P
geposted Thu 09 Feb 06 @ 8:49 pm
