i would like to be able to chose if triggering a sample when it is allready beaing played stops the sample or if different triggerings of the sample are created. also loops that can be made to a size other than 4 beats (without having to loop the active deck).
beatlock that keeps to the beat without such a destructive time stretch. a beatlock that mutes the sample when doing hard scratching (does anyone want to scratch the deck and sample together?) would be good and make the samples well integrated into playing with TCV TCCD.
it would also be cool to have autogain set a volume for new samples you load so you dont have to ether setup monitoring for them to get the level rite or do it before your set.
geposted Fri 10 Feb 06 @ 2:51 am
i guess its not such a good idea after all
geposted Sat 18 Feb 06 @ 1:04 am
