Can someone tell me why the program will load up and play for about a minute, then disappear?
geposted Fri 10 Feb 06 @ 5:44 pm
Sounds to me like your trial version has run out. It only lasts for 20 days and after that it stops after about a minute of playing.
Purchase the full version here: virtualdj.com/purchase - that'll solve your problem.
Cheers...and keep spinnin'...:o)
P
P
geposted Sat 11 Feb 06 @ 1:46 am
I am having the same problem. I purchased the real version about 2 weeks ago, it works fine when I play songs, but when I play any videos, the program gets not quite 1 minute into it and the program just shuts off. any one know what might be the problem?
geposted Sun 12 Feb 06 @ 1:03 pm
@rickhype
Post your system specs and try and describe exactly what's happening.
What video are you playing? Are you using any effects?
P
P
geposted Sun 12 Feb 06 @ 6:31 pm
