I would like the "Red Already Played Icon" to be date regulated, not boot regulated. What I mean is, if you have to reboot, you lose the red played icon, on the tracks that you played. While you are at it, make the clock available in a 12 hour option.
geposted Sat 11 Feb 06 @ 7:09 am
aggree with both those. and while your at those two make a better default skin.
geposted Sun 12 Feb 06 @ 6:10 pm
Point1: During one mixing session I never reboot my system, why you reboot? During the reboot the people in the hall what can they listen? Probably there is some problem on your Virtual DJ.
Point 2: In the skin option you can modify the XML end insert
%fullhour : display the time in a hh:mm:ss format
%hour : display the time in a hh:mm format
But not 12H, for me this is not necessary.
geposted Tue 14 Feb 06 @ 11:32 am
Yes the icons for seeing if you have played a track or telling the difference between an MP3 and a video file are difficult to see. Maybe I need to try some new skins?
geposted Mon 20 Feb 06 @ 3:04 pm
