Hello! I want to buy the timecoded vinyls and a soundcard. At this time I want to know any possible soundcards that I can use with VDJ in order to have some good results.
External soundcards only!
geposted Mon 13 Feb 06 @ 3:40 pm
For a long while, the Maya 44 usb external soundcard was the favourite.
I'm sure i've heard that this is now changing...but i can't remember what to. In any case, if you're looking to get tcv's and stuff, this is certainly the type of card you'd be looking for.
Cheers...and keep spinnin'...:o)
geposted Tue 14 Feb 06 @ 11:33 pm
Only externals...
1) Maya 44 USB (if you find it) $119
2) ESI U46DJ USB $199
3) M-Audio FireWire 1814 $399
4) If you like to have a controller and good soundcard (not very good, but do the job) use a DJConsole MK2 $249
Good Luck!
Good Luck!
geposted Fri 17 Feb 06 @ 11:03 pm
