just wondering if there is an estimated release date for the updated vdj. I'm a tcv & tccd user & can't use this program until the tcv prolems are ironed out. I really love the posibillties of the software. However I have'nt got any bang for the money I've spent. I bought 2 technics 1200, Gateway 2.8ghz 1gig ram, new djm707 mixer all road ready cases & etc. just for me not to be able to use the program at all. I'm sort of frustrated, but I'm trying to hold on before I cut my loses & try other tcv software. I tried all the suggestions in the forums to no avail. After installing a gig of ram & still no success, I'm about finished.
geposted Tue 14 Feb 06 @ 6:27 pm
Many people use VDJ and TCVs without any problems. If you could describe your problem(s) then more people will be able to help. The 1GB RAM will help a lot, but there might be something else that's causing trouble.
Did you check your ASIO settings? Try following this tutorial if you haven't already:
https://virtualdj.com/support/VirtualDJ%203%20-%20Advanced%20ASIO%20configuration.pdf
geposted Tue 14 Feb 06 @ 7:12 pm
