Anyone know how to fix cd player? I have a numark cdn-88 and both players are reading no disc.
geposted Thu 16 Feb 06 @ 1:45 am
Sounds serious. Turn it in to the dealer you bought it from. Don't think clensing the laser heads with some cheap cd cleaner is enough.
geposted Thu 16 Feb 06 @ 12:59 pm
That could be for a number of reasons, if the player is no longer under warenty open the player case and clean the laser opticals with some pure alcohol using cottontips.
That's about as much you can do yourself..
geposted Thu 16 Feb 06 @ 5:17 pm
I have the cdn-88 and it is a tracking issue, you should be able to order new decks from numark.
geposted Thu 16 Feb 06 @ 6:17 pm
