Forum: VirtualDJ Plugins
Topic: New sound effect !!
Can u plz put this sound effect it's like that ..
1. the track remains playing as normal
2. it makes a loop (taken from the track playing ) (adjustable 1b,2b,4b,etc)
3. the loop plays over the main track ( with the main track playing normally)
4. and put a fader option for the loop so it can lower the volum of the loop with time
hop u get it ...Co0lDJ (hisham majzoub)
geposted Thu 16 Feb 06 @ 11:05 am
try overloop plugin, or maybe it needs to be updated a little .... :-)
Already exists - see ECHO OUT effect
I confirm that digijoc-Mele is right ;-)
ok thanx for dat ... :S ...
why is it that when i use echo out, i have a split second (but very noticable) pause for a second in all music and then the effect picks up... does that happen to everyone is is my machine just a little too slow? pentium 4, 1.8 ghz, 800 RAM
Thanks deun deun for the JetlagV2, very good work!
cioce
it ok, you're welcome !
tanks
Very good effect works great!
Jetlag V3 is in progress :-)
what will jetlag v3 contain, im looking forward to it
chekin
thank you
thanxx for ths one :d
thank youuu:)
