Hello.
Recently I bought a TRUST External Soundcard...this one:
http://www.trust.com/products/product.aspx?artnr=14134&show=1
I want to know if this one can work with the timecode vinyls.
Thanks!
Thanks!
geposted Thu 16 Feb 06 @ 5:11 pm
it will work with ONE timecoded vinyl as it only has one line/microphone input.
but as it isn't ASIO you will have a big latency if you use it with a TCV.
geposted Thu 16 Feb 06 @ 5:31 pm
...unless you use something like ASIO4ALL
https://virtualdj.com/support/VirtualDJ%203%20-%20Advanced%20ASIO%20configuration.pdf
geposted Thu 16 Feb 06 @ 9:08 pm
ASIO4ALL must be your last resource. It's better to work with soundcards that support ASIO mode. Also we need 2 stereo line inputs and 2 stereo line outputs (at least) to work with TCVs or TCCDs.
geposted Sun 19 Feb 06 @ 9:00 am
