Does anyone own one and have been sucessfull in configuring it VDJ with video mixing using the crossfader? I was planning on buying one and using it in conjuction with my DAC-3 and TCV's. I would love to have the combo with the crossfader set for video transition. Before I drop $$$ I want to be sure this can be accomplished. Also, is it possible to rack mount that mixer in a 19inch case? are there adapters similiar to the pioneer mixers?
answers, suggestions, comments welcome!!!
thanks in advance...
- AL
- AL
geposted Thu 16 Feb 06 @ 8:27 pm
I am shocked that no one here actually owns one or has anything to say about this wonderful mixer. I want to buy one... but I am afraid.... a lot of money if I can't get it to work the way I would hope
geposted Mon 20 Feb 06 @ 8:55 am
We used a Nuo4 for the SIEL 2006 in France last week ;-)
geposted Mon 20 Feb 06 @ 11:08 am
love your lengthy comment....
so... did you use it in conjuction with VDJ? do you use the crossfader for video? blah blah...?
geposted Mon 20 Feb 06 @ 12:22 pm
yes the crossfader was used for video. and the four buttons under the center midi knobs where used to control play and stop on VDJ just for a test and it worked great.
you can use any shortcut in VDJ to be controlled by midi, and this includes the Ecler Nuo 4.
geposted Mon 20 Feb 06 @ 1:19 pm
what about while using a DAC-3 or any other midi device? do they have a conflict if that happens?
Can the mixer be rack mounted in a 19inch rack? what is the width if I did want to get a case for it or rack it?
geposted Mon 20 Feb 06 @ 9:07 pm
it is 12.6" wide.
you will need to have an adapter to rack it, or build a case yourself.
geposted Tue 21 Feb 06 @ 2:45 pm
