Problem #1
Sometimes I get a very slow response when playing with TCVs. It can be as bad as ½ a sec, which completely ruins everything. What can be the cause of this? I have tried shifting from 44 -> 48kHz which sometimes helps, sometimes don´t change a thing.
Problem #2
I have just got a new laptop and after I installed U46DJ and VDJ on it I cannot get it to handle 2 input signals. When configuring time code, I get the signal from turntable 1 in both channels. Putting a TCV on turntable 2 has no effect. I cannot understand this. Input is set to: left deck 1/2 right deck 3/4. But 1/2 now also goes to 3/4. WTF?
Specs
VDJ 3.3,
Pentium M 2.13 GHz
1 GB RAM
60 GB 5.400 RPM / 8 MB cache
1210 MKII
ESI U46DJ
XP Pro SP2
Problem #2
Specs
VDJ 3.3,
Pentium M 2.13 GHz
1 GB RAM
1210 MKII
ESI U46DJ
XP Pro SP2
geposted Sun 19 Feb 06 @ 9:57 pm
I should maybe add that I have had Virtual Audio Cable installed on the laptop prior to installing the U46DJ and VDJ. But after experiencing these problems I have uninstalled it - not that it helped...
geposted Sun 19 Feb 06 @ 9:59 pm
