I've just downloaded Size Fall v1.0 from the video effects page: http://www.virtualdj.com/addons/view.html?type=video%20effect
Anyone know what it does? It says that it "Decrease's/Increase's the size of the video while moving the video crossfader"
I'm using virtual Dj 3.3 and can't see it doing anything to the video no matter what? How do I use this plugin? Does it work? Or is it just me not doing something properly?
Thanks.
Thanks.
geposted Sun 19 Feb 06 @ 10:07 pm
I have just changed this plugin lol
Download it again ;-)
It decreases the size of the picture until the middle of the crossfader
geposted Sun 19 Feb 06 @ 10:20 pm
Got it to work eventually.
I wasn't selecting it in the right menu. You have to set it as one of the transitions.
I was just selecting it in the "FX Plugin" list like all the others. No wonder! DOH!!!
Config > Video > Transitions.
geposted Sun 19 Feb 06 @ 10:59 pm
Yes that's why i changed the exe: it was not sent in the good folder: it's a transition so you can delete the one in videoeffects
I advise you freeframe video effects too ;-)
geposted Sun 19 Feb 06 @ 11:01 pm
