Forum: Old versions
Topic: Window of management BPM
At the given moment, the window of management of the BPM seemed relieved. There was not more than a possibility of encoding a figure, of doubling or of dividing by 2 the result. The tab of change CBG did not appear any more. I did not hesitate and reinstalled the VDJ. The problem disappeared. Strange phenomenon...
geposted Sat 15 May 04 @ 6:23 am
The full bpm window is displayed only when the song is analyzed. If your song is not analyzed then the window you describe is open.
Gwenn
I think the full bmp management window will come up only if the song is playing.
i'm with rick here, the song must be both analysed and open for the full bpm managment. dometimes if it has just been analysed by draging it onto the deck you must redrag the file in order for it to bring up the correct bpm managment window
