Just downloaded "Gradient de Roberts" - by kaleo -
from this page: http://www.virtualdj.com/addons/view.html?type=video%20effect
But what does it do? I'm using Virtual DJ 3.3 and can't make this plugin do anything. Where am I going wrong? Any suggestions what I can try next? I've already re-installed it several times still can't get anything from it.
Cheers.
Cheers.
geposted Sun 19 Feb 06 @ 10:44 pm
I think it depends on your screen card.
it doesn't work on my computer as well.
geposted Thu 23 Feb 06 @ 5:08 pm
Yes you need a video card which supports the function Pixel Shaders
geposted Thu 23 Feb 06 @ 5:23 pm
moreover, it seem to work better with ATI cards.
(you need PS 1.4 minimum)
geposted Fri 24 Feb 06 @ 8:46 am
